Radio Facia
altezzadamo
hey guys does anybody know where i can get a radio facia
for my altezza :blink:
Story Damo,
You can get one off Suped, which is the one i got. Very tricky to put together and ok quality. Cost me 70 euro. Saw another one on icebuyer for 45 euro
The one i got is interchangeable so u can fit a single din or double din headunit, or change it around if you every buy anything different
What model do you have? If its an Altezza rs200 with the external amp behind the glove box, its not a straight forward install for the new HU
[quote
cheers, yes its the rs200, i'll try suped its only down the road
The lads in suped dont know much about altezza audio and wiring, you can probably get the facia there no problem but you should check and see if your car has an external amp which i think it does. If this is the case no after market HU will fit in to your car without doing some wire chopping/extending etc. Suped might try and sell you a TOYOTA ISO ADAPTER for 15 Euro but this does not work on systems that have an external amp. So dont waste your money like i did!
:offtopic: PM me if you want to meet up and we can discuss this more
