Hi folks,
I just put 2 new head light bulbs in my S1, but something funny has gone on with the high beam.
The headlights are fine when on normally but when I pull the lever to flash the LHS high beam comes on and the second fillament in the LHS head light comes on (I assume this is correct, it's what used to happen before). On the RHS/driver side the headlight seems normal but when I flash the high beam does not come on, the second fillament in the head light does not seem to come on, infact the headlight seems to get dimmer :blink:
I checked that the connection in the high beam is ok and that the bulb has not gone, struggling to explain the dimming of the headlight though :unsure:
anyone had anything similar before I have to fanny around in the dark with a multi meter! :ohmy:
