How Low Can I Go?
Laltezza
I just collected my rs 200 on monday and it is even better than i expected!!the only thing is that it is on hks adjustables and its a bit too low for d (rubbish) roads around here so i need to raise it up....does anyone know if this is something i can do myself or is it something i want to get a specialist to do?also anyone recommend a sensible ride height?
provided you have the necessary tool for adjusting them then you should be able to do it your self....
as for ride height that's a personal choice, experiment!
keep an eye on tyre wear afterwards as you may need to get the camber adjusted to suit, that's assuming it was setup up already in Japan by the last owner.... ;)
