Inconsistent Sound Cd Vs Radio In -95 Ls400
This an odd "problem" in my -95 LS 400 with standard radio/tape/CD-changer combination.
If I listen to the radio, the sound is full, without being overly heavy in the bass. Actually it sounds really good if one avoids the horribly compressed and distorted commercial channels... :)
I run the tone controls flat, or perhaps with a minor increase in the treble.
If I however switch to CD, the sound changes alot. The sound is thin and tinny, and to duplicate the well balanced sound of the radio, I have to turn the bass control to 3 o'clock, and the treble to 10 o'clock.
Basically it feels as the whole frequency curve is tilted, little bass and too much treble... :huh:
It is not just in relative terms, the sound IS thin and tinny. There are no other problems with the CD-changer; no skipping or reading problems.
Any input is much appreciated!
/Alexander from Sweden
Thanks! On the contrary - it IS good help. :)
There is a possibility that this a design flaw, and not an effect of damaged components...
On the other hand, I wonder if there perhaps is some 6dB/oct. DC filter capacitors on the CD input. If those capacitors dry out and deteriorate, the HP frequency will move upwards. Just a thought.
