Random Loss Of Power
have a GOOD look at the small pipes that connect the intercooler to the main pipework - it can look that the pipes are properly fitted but if the clip has worked loose the pipe can move a bit and as we are running a low pressure, even a very slight leak can cause substantial power losses.
Tightened the hoses I could get too and it has made a difference but I cant get access to the ones connecting the intercooler, any ideas?
Sorry to head off topic, but Cho, have you got the HKS rear bumper fitted? Just looking at your avatar and it appeared to be the HKS item...?
Regarding the hose clamps that connect to the intercooler, they should've been positioned so that you can push a Philips screwdriver through the front grille and tighten them that way. Funnily enough, I've just done all mine this dinner time.
Cheers,
Jamie
Cheers,
Jamie
Hi Jamie,
Yes, I finally got It all done will take some proper pictures with a digi cam and post them up asap. Full aero kit just need some nice wheels to finish it all off.
Thanks for the tip about the hoses.
