Gs300 ('98) Weird Alarm Problem?
Hi Guys, (& Gals of course),
Got a strange one for you, my alarm will not set although the central locking does? here's the sequence...
1st Press on fob = Doors Lock & indicators flash (single) - AS NORMAL
2nd Press on Fob = Doors Re-lock, but no indicator flash (normally this is 5 flashes)
Now if I set off the alarm by opening the doors, boot or bonnet, just the horn sounds (normally it's both horn & alarm sounder), also I cannot trigger the alarm by moving around in the car (Microwave sensor).
I presume there is an alarm problem and what I'm left with is a sort of fallback or backup system.
Does the alarm have a fuse, i have checked under bonnet but it's not labeled in the fuse box.
Any help would be much appreciated
Thanks in advance
Nigel
