Update To Poor Celsior Blowers
OK, under my dash in my 1991 Celsior there was no piece held by two wingnuts that looked anything like the pictures or photos I had seen.
Instead I had
The largish white box in the centre right is just about the only thing visible. except wiring connectors.
After working out that the lower dash was held by 3 clips with screws in at the back/bottom edge, not 1 plastic rivet I could completly remove that.
I could see the white plastic box had a removable end. But it was held in by 5x8mm bolts.
After removing them I could get to the filter.
Just one filter, slightly small than A4 paper size, that has two folds inhorizontally it to allow folding into 3 for fitting.
There was no other filter there, and the bottom 3rd was roughly twice as thick.
I tried to vacuum then clean it as it was fabric rather than paper, but a lot of crud has been left as sludge.
I refitted the panel without the filter as it doesn't want to go back inbecause the carpet/floorpan was in the way.
The part number was Densp 014520-0050
Hope this helps someone.
Currently running without the filter, and yes, now I have blower output. Very good output.
I've tried to clean the old one to try and get a decent photo, so anyone with a Celsior can see how different it is to the LS and SC filters.
I'm going to wait until I can find a new filter.
