How To Pause Audio Playback In Mark Levinson Audio?
it would be ok if there was a revision after a considerable time had passed since the car was released because you cant rele stop progress to keep up with the latest technology/competition as you said about the Bluetooth, but memory function for the seats isnt that much of a big deal that they had to wait a year and the put it on the car and its not like that had to develop the technology and test or anything, all they had to do was get another drivers door remove some electric window buttons and the bolt it on the passenger side.
i know what you said is completely true but i feel a bit short-changed in a way.
it would be ok if there was a revision after a considerable time had passed since the car was released because you cant rele stop progress to keep up with the latest technology/competition as you said about the bluetooth, but memory function for the seats isnt that much of a big deal that they had to wait a year and the put it on the car and its not like that had to develop the technology and test or anything, all they had to do was get another drivers door remove some electric window buttons and the bolt it on the passenger side.
Hi
I recon they didn't have enough space in the brochure to fit it..... :whistling: never mind, just play with all of these and when you get to the end you will have forgotten all about it :whistling:
LS600H specification
ABS (Anti-lock Braking System)
Adaptive Cruise Control and Pre-crash Safety System
Advanced safety pack
Air suspension
AVS (Adaptive Variable Suspension) with sport/comfort modes
BAS (Brake Assist System)
EBD (Electronic Brakeforce Distribution)
EBS (Emergency Brake Signal)
ECB (Electronically Controlled Braking)
EPB (Electronic Parking Brake)
EPS (Electric Power Steering), speed-sensitive
TPWS (Tyre Pressure Warning System)
TRC (Traction Control System)
VDIM (Vehicle Dynamics Integrated Management)
VGRS (Variable Gear Ratio Steering)
VSC (Vehicle Stability Control)
2-stage airbag, driver and front passenger
2-stage twin-chamber airbag, front passenger
Airbag cut-off switch, front passenger
Audible seatbelt reminder
Curtain shield airbag, front and rear
ISOFIX attachment, outer rear seats
Knee airbag, driver and front passenger
Rear side airbags
Seatbelt pre-tensioners, front and rear outer seats
TAP (Thorax Abdomen Pelvis) airbag, driver and front passenger
WIL (Whiplash Injury Lessening) front seats
Anti-theft system, immobiliser, intrusion sensor, inclination sensor and siren
Auto door locking
Double door lock
Door mirrors, electrically adjustable, heated and folding
Door mirrors, electrochromatic (auto-dimming)
Easy door and boot close (soft shut)
Front foglights
HID (High Intensity Discharge) bi-xenon headlights with auto-levelling
I-AFS (Intelligent-Adaptive Front-lighting System)
Laminated glass for windscreen and side windows
LED tail and brake lights and licence plate illumination
Light Emitting Diode (LED) low-beam headights
Parking assist sensors, front and rear
Power boot closer
Rain sensing wipers
Recessed pop-up high pressure headlight cleaners
UV and heat insulating tinted glass
Water repellent glass, front door windows
19 Speaker Mark Levinson Audio
8" colour touch-screen EMV (Electro Multi Vision) VGA display
Advanced obstacle detection system
Bluetooth mobile phone connectivity
Colour TFT multi information display in centre instrument cluster
Driver monitoring system
DVD Navigation system with DRG (Dynamic Route Guidance)
Emergency steering assist
In-dash, single-slot 6-DVD autochanger
Intelligent Parking Assist (IPA)
Optitron instrumentation
Parking assist monitor
Rear Pre-crash safety system
Rear seat entertainment
Steering wheel mounted controls for audio, phone, voice command
Voice command, audio, navigation, climate
Air conditioned front seats
Air diffusers, roof-lining mounted
Automatic recirculation control
Clean air filter with pollen removal mode
Cool box
Cruise control
Dual lumbar support for driver seat
Easy exit and entry (retracting steering wheel)
Ecsaine® pillar-finishing
Ecsaine® roof-lining
Electric sunroof
Electronic climate control air conditioning system
Front headrests, electrically adjustable
Front seatbelt position, electrically height adjustable with memory for driver
Front seats, electrically adjustable, 10-way (driver), 8-way (passenger)
Heated rear seats
Illuminated entry system with puddle lamps
Illuminated front and rear vanity mirrors
Leather and wood trimmed steering wheel, heated
Leather dashboard and upper door panels
Leather trimmed steering wheel and gearshift lever
Leather upholstery
LED interior lighting
Lumbar support, electrically adjustable, 4-way driver, 2-way passenger
Memory for seats, steering wheel position and door mirrors
One-touch electrically operated windows, front and rear
Rear centre armrest
Rear headrests, electrically operated
Rear seats, air conditioned
Rear seats, electrically adjustable with memory
Rear sunshade, electrically operated with auto-lift and lower
Rear view mirror, electrochromatic (auto-dimming)
Semi-aniline leather seats
Separate driver/passenger temperature controls
Smart card entry
Smart entry and start system
Steering wheel, electrically multi-adjustable
Upholstery upgrade package
Wood inlays, doors, instrument panel and lower centre console
I do know what you mean though... they put Adaptive Cruise Control on the 2001 LS430 US spec car.... why not on mine???
Pete
