Is The Sc The Same As Gs
IanCornwall
The reason I was asking is that I am after a couple of Lambda O2 sensors and found this site
They assure me that I need a 4 wire Lambda sensor but mine has a 1 wire and they say that is listed under a Lexus SC300 spec and american specs GS300 had a 4 wire system although they basically had the same engine
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=200137754206
http://cgi.ebay.com/ebaymotors/O2-OXYGEN-S...54206QQtcZphoto
These are so cheap for parts I just feel that I have to give them a try
What do you think ?
Can't see why not to try them. I'm sure when I looked at mine they had 4 wires, but I could be wrong. As long as the replacements have the right number of wires, and you are happy to cut and join wires to the existing connectors, then they should work no problem.
Hi Tiger
Is yours a Mk 2 with VVTI ? mine is a Mk 1 without, I am led to believe from someone that the change from 1 wire to many wires was during that upgrade
Hi Mate,
Mine is a Mk 1 too, I'll pop outside in a mo' with a torch and take another look.
Just checked. It has definately got 4 wires on the two in the engine bay. I would assume the one under the car has 4 too.
this is wierd
I went and double checked mine in case I was losing it, and even pulled the plug in case it has very very small wires, mine is definatley only a 1 wire sender and 1 wire connector in the loom
suggestions anyone ? is my car made earlier than I thought but registered later as does happen
Only thing I can think of is that the sport came in on 96, so maybe that tied in with some minor changes to the cars in general. I'm sure I've read somewhere that the auto gearbox changed slightly in 96 also. Mk1's didn't go out until 97 so it could only be an under the skin face lift on the electrics that could account for it I guess.
You can't lose at that price either way.
