Suspension Work & Alignment
Rogue
Put the IS into MH Engineering up here in Aberdeen. It had not had the alignemt done since I lowered it & changed the wheels plus I had an extremely annoying squeak form the rear of the car. MH specialise in suspension set up for hill climbs & track cars. I had asked Tony (WIM) some time ago if he could give me the settings for the IS as I could not make it down to WIM & he kindly agreed. So I took the set up instructions to these guys & suggested that they have a look which they were happy to do. Left the car for a couple of days & called to see how they got on. Car was re-aligned & some of the joints required some work. The squeak was caused by poorly lubricated bushings on the rear TRD ARB. So when I picked the car up I asked about the Docs figures. They used the exact set up Tony suggested and the car handles a treat now. Had been a bit twitchy around roundabouts prior to the work but now all handles really well & no more squeaking :D . So thanks to Mark & Alex at MH Engineering & to Tony (WIM).
