Top Front Ball Joint?
bristows_lad
It's part of the top wishbone so you'll need the whole lot .... :(
Lexus OEM Front Suspension Upper Arm Assembly LH part no. 48630-59025
not going to be cheap from the dealers ....
HTH
awsome.
its coming wednesday. many many thanks.
they hard to fit urself? or garage jobbie?
separating the ball joint bolt from the the top of the hub is a pain, you'll need a proper tool for that, the rest is just time consuming as the Battery and base has to come out...
good luck :)
