problem as above when key is removed column does not retract fully,also when changing memory positions from 1 to 2 {or 2 to 1} column does not take up corect position,when changing to position 1 for instance seat,mirrors,headrests etc all ok but need to press button 1 on door several times for column to get to correct position,i believe that column is controlled by a module,and this is a fairly common fault,what i need to know is 1 is the module repairable eg dry joint fault or does it have to be replaced 2 where the hell on the car is it, any help would be greatly appreciated
