Rear Brakes- Easy To Do?
When changing pads make sure you use a dab of copper grease around the caliper piston and on the back of the pads. It is something that is often overlooked and failing to do this can result in the pads or caliper seizing up. Make sure that the pads move freely. If they dont you might have to sand a bit off the lugs on the pads.
