Bonnet Catch
clarec9183
hi all,i was wondering if anyone knows if you can adjust the bonnet catches in the is200 as mine doesent seem to pull the bonnet down enough,i have tried adjusting the rubbers on either side but this just makes the bonnet higher than the wings,,please help.
screw the rubber in, this should lower the bonnet,
however the catch is adjustable there are 3 10mm screws holding it onto the slam panel and vertical support
i've tried adjusting the rubbers already,and i also loosened the three 10mm bolts but couldnt move the catch down at all,is there somthing im missing,thanks for your time.
