Coil Packs
tinygsy
Are all the coil packs the same on an 01 IS200? Reason I ask is there is an error code showing that cylinder 1 has a missfire but when the mechanic tested the coil`s they were all fine so was thinking about swapping a couple around to see if the code appears on another cylinder
