Which Are Best,
kallabungo
I've been given a pair of prada spec 2's and a pair of proxes in 225-40-18 all with good tread.
I was just wondering which would be the grippiest with the current east of england weather conditions...?
I intend to have the grippiest on the front, i hate understeer!
Thank you :)
I had a few issue`s with the Toyo T1-R`s on my IS200 sport.....had them on the rear ( 225/40/18 ) but the chassis hated them on the rear felt like it was fish tailing when doing speed so moved them to the front and put the pressures up to 38psi
I actually think they perform better when it is wet and not that hot as the more heat that they generated the more they would understeer ( on the front )....i had lots of testing of the tyres with Tony down @ WIM to get a good medium in regards to PSI etc...apparantly the sidewall is to soft for the IS200 chassis so if you do use them put them on the front and set to 38 psi...
