Wim Specs Tracking
I know this has been dragged to death but help please. I have been looking for WIM geo settings ref all the tracking specs. My misses 01 is200 sport has killed her front tyres and well its time for renewal so if some one can post me the links or send me a pm with the specs that be really greatful.
thanks
Jules
Everything at the rear is set to stock positions.......
Front
Camber -10 to -15'
Castor will indirectly adjust more positive and may even violate UK positions, don't worry about that.
Toe: stock: When the camber is adjusted it will dramatically displace the toe, this is necessary to indirectly adjust the castor so don't worry about that.
A good technician may comment the toe correction will reduce the lock angle, this is true but only noticed by the 3.5 turn rather than a 3 point turn.
Front
Camber -10 to -15'
Thank you very much. I live outside of the UK, so this could save me more than a set of tyres - will probably have to do the geometrics after the winter. Thanks once again for sharing.. Sharing is caring :)
