Led Door Sills Custom How To
so the first thing you need to do is get some led's , i got these
then you need to remove the door sills from the car which is done by placine a flat screew driver under then and popping off the plastic holders....
then when you have them home you need to remove the metal plate by lifting the metal tabs from the back
then you need to remove the large plastic plugs only
i used a knife for this and just cut off the back of the plug so it can be popped out
so you end up like this
then you need to put the metal back together with the plastic and drill the holes for the led's ... i usen a 5mm drill bit but check what size you leds are.
after drilling you need to clean up the back of the plastic with a knife to remove any bits of plastic left
then you need to glue the led's into the plastic
then solder it all up and check that it's all working good
then you need to put it in the car and hock it up to the light loop from the key barrel unit.
and there you go.. everybody has a light door sill
hope this helps you
jason
