Help Fitting Kahn Rs-c 18x8 In Is200
B_I_T_O
Hello! I have bought a set of wheels, the Kahn RS-C 18x8, and as I was expecting, they are too big and when I'm driving, they damage the plastic inside the whell place (don't know the proper name for that lol).
I have to repair them and paint them again, so I would also modify them, so whoever does the job, can also modify the wheel to the specification that I need for them to fit nicely.
Can you guys help me? What size should I ask for? 7,5"?
Thanks from Portugal! :)
modify the wheel??make it thinner ????you cant do that!!!!! i too am runnin 18's and so is a lot of the members and i dont think any of them have rubbing issues....
what tyre size you using and whats the offset of your wheels??
i'm running et35's too you have two problems that can be solved at once......your side wall profile is too high should be 40 also due to you running that offset the wheels sit further out the tyre size i run is 215 40 18's and i have no problems with my wheels rubbing..hope that helps mate.
