if some really nice back boxes were added to a system would it be very boomy at certain revs i.e low
Sounds changes differ from maker to maker. You can you tube some videos if you want to hear some different sounds from them.
Ihave some RSR from japan on mine, They have a four inch wide exit.
Have a look at the exit shape and then decide what type you want to go for.
If you want a full on noise then remove the middle silencers and fit a straight through sytem. Also get an air induction kit fitted if you want a more louder roar on accelerating from the front. That turns heads when flooring it.
