Tyre Pressure...
lex28
hello...
was at petrol station yesterday to check pressure in my tyres as i do every month, and set pressure for 33psi...
the drivers rear wheel was indicating 'N' on the machine.....what does that mean???
thanks
Not sure on what N means. Faulty gauge or valve possibly. You should try 35psi. WIM recommend it. I found it makes a bit of difference to the way the car feels on the road as well as helping with tyre wear.
Does the 35psi apply to all wheels on the Is200 or just the OEM 17" ones?
