Rx300 Brake Pedal Slowly Go Down ?
Hello. I have a 2004 Lexus RX300 with chassis JTJHF31U800020658
I notice the brake pedal is going down when i depress and hold it at certain position.
I already replace the brake cylinder pump right in front the brake booster. I did bleed the brakes with correct steps.
There were no brake fluid leaking and the fluid level is MAX.
Did i miss something ? or its another symptom causing it to fade ?
