Driving Lights for my sc300
andy66ny
Are you in the UK? If you are then this is the answer, if not then check the law where you are.
In the UK you are required to have Full, Dip and indicator(turn signal) lights on the front of the car, any others are additional. If the corner lights are orange and the only signal indicator at the front then you have to leave them. If they are clear and are additional to front indicators then it's a simple mod.
Join a wire from your full beam to the lights you want to convert and they will come on as driving lights. It was a mod all 205Gti owners used to do with there front fogs!
[Edited on 18-4-2002 by brn7y]
  • 10 months later...
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
