Help Buying 2002 Is200
aliworld
Hi, I am looking to buy an 02 / 03 IS 200 SE with about 60k on the clock. What should I look out for when inspecting the car?
Hello & welcome.
First of all check the service history - these cars are almost bulletproof provided their looked after. low milage examples- especially at that age should have had their cambelt changed, these can be quite costly so if it hasnt had this done deduct £300 - £400 from the asking price.
Secondly - check the alloys, they do corrode quite badly, make sure they're in decent condition
Thirdly - check the Cd player, ideally take a cd with you, press load and pop your cd in when the light turns green. The Cd players are good, but if its a faulty unit it will come up ERROR 4 etc on the screen and wont play you Cd. this can be expensive to replace/ repair and most fit an aftermarket unit because of this.
the last thing I would check would be to HPi check it, as with all cars - this includes the engine/chassis number. Cars can be easily cloned, so walk away if your not certain/sure.
im sure other members will add to my post, but i consider these the most common things to look out for - aside from the obvious.
Hope this has helped you
lloyd
A full HPI check can be expensive, but a "mytextcheck" (www.mytextcheck.com) only costs £3 (plus standard network rate).
I wish I'd remembered it when I bought mine!
Just text the reg no to 83600 - well worth £3 for peace of mind.
yes very good tip :)
