I've noticed that the rear tyres (Pirelli) on my IS250 are wearing unevenly. They're only about a year old and have covered about 15K miles, but are down to only 3mm in the centre whilst towards the edge I've got about 5mm+.
Have I got my pressure wrong (38psi) or is this just a sign that I shouldn't buy Pirellis again?
38psi is at the lower end of the recommended range (and supposedly suitable for driving below 100mph). I'm worried that if I increase the pressure the tyre will become more 'rounded' and cause the centre to wear even faster than it currently is.
The Toyos that I had previously wore very evenly and lasted 30K miles and were inflated to 38psi too.
Does anyone have any advice?
Thanks.
Tyres are over-inflated, drop the pressure to 35 psi unless you are running with four-up and a boot full of luggage.
Tyre wear in the centre is definately due to over inflation. As the last post suggests - drop the pressure slightly and you should notice a difference.
Thanks for the responses. I suspected that I should drop the pressure.
Just for the record, I spend most of my time cruising at 70mph with no luggage or passengers.
I'll drop the pressure to 35psi and keep an eye on things. Hopefully I'll get a little more life out of them by doing so.
Thanks for this post, reminded me to check mine.
15,000 miles, Bridgestone Turanzas on 18 inch wheels. Inflated to 35 front and 38 rear as per handbook. 90% of mileage with passenger and no luggage. Wear is even across rear at 5mm and front at 6mm.
