Headlights
xn1ck0x
You would need to check that the USA version are correctly deflected in order to light up the side of the road that we drive on over here. ie: That they are designed for use on Left Hand side of the road.
Also if they are normal with halogen lamps or the HID Xenon type which would require ballast packs and wiring too!
I just had a look at mine (IS300) which are HID type and cant see any deflectors within the glass moulding, but the reflective dish surrounding the headlight lamp seems to be ribbed which may deflect the light.
I do hope i have made you more aware and not confused the issue more.
My advice is simply to check into what i have outlined first mate.
Other than that, they will fit!
