Transmission Failure
RX300-SE 04REG, 44K miles
HERE ARE SYMPTOMS/ISSUES IN CURRENTLY EXPERIENCING :
CAR ALWAYS A DELAY WHEN IN FORWARD GEAR & WEN IT EVENTUALLY MOVES IT JUMPS OFF/(JUDDERS) LIKE THE CLUTCH IS SLIPPING
SOMETIMES ILL NEED TO FLOOR THE PEDAL BEFORE GETTING THE CAR MOVING & IT STARTS DRIVING LIKE NOTHING HAVE HAPPENED
WHEN DRIVING UP THE HILL, UNABLE TO GET TO THE TOP, THE CAR STOPS WHILE ENGINE STILL RUNNING. ILL HAVE TO FLOOR THE PEDAL TO GET A BIT OF MOVEMENT WHICH USUALLY RESULT IN THE SMOKE & SMELL OF A BURNING CLUTCH
CAN SOME ONE HELP ME OUT HERE PLEASE, LET ME KNOW YOUR THOUGHTS
HI, it soulds to me as if your very low on transmission fluid, have you checked it ?
Yes, you are right
Lexus got back to me today saying my transmission fluid is low which is as a result of broken drive shaft seal
The seal cost £12 and it will cost me £300 to replace it
PLS DOES ANYONE HAVE THE PART NUMBER FOR THIS SEAL, THIS IS THE SEAL THAT PREVENT THE TRANSMISSION FLUID FROM LEAKING THRU THE DRIVE SHAFT
