Relocating The Horns
ive just done the very same, relocated mine behind front bumper.On mine there was a black plastic plate across rad gap after i removed grill.After removing horns i was able to lift plastic and locate the bolts which held it to bumper and then mount horns on removed bolts.
If you dont have plastic bit should still have threaded holes in front bar.
