Atf Change
Having transited from a Mercedes and having changed the gearbox fluid on it as it was recommended by members on the forum there I was thinking of doing the same to the IS200. I have bought it when it had 96000 almost two years ago but now the car has gone over 130 000 and even though I have no problem with it I think is due a change.
My question really is.. has anyone done it on the IS200 and how difficult is it?
NIk
NIk
hi easy aslong as you can get the car up in the air as you also need to take the sump off to clean or replace the filter hope this helps
