Misfiring When Warm
Fugu
Hi All,
My friends is200 is misfiring when warm, so far he has replaced the spark plugs and the coil packs to no avail!
However he said it started after he parked his car on a hill, by all accounts up to 4 cylinder stop. After he changed the spark plugs he said it was like a new car, until the next morning when it heated up and started again.
Has anyone had any experience with this or have any pointers?
i know that problem...
it must be the HT cables,need replacing.cables that connect to the spark plug.happens when they are worn out causing misfiring.last resort if you changed everything else.the problem you cant know if they are faulty or test them.had the same problem changed them n no issues since
