Reset After Battery Disconect?
sp107
Hi have just got a RX 400h (at a very good price) but it had been standing for 6 months so the Battery had gone flat. I have read somewhere that things need to be reset, what? and how?
Are there any known regular problems? I have just checked on Lexus web site and my car is on a recall but won't tell me what for!!
Iv'e only had it for a day but love this car :phone:
Hi have just got a RX 400h (at a very good price) but it had been standing for 6 months so the battery had gone flat. I have read somewhere that things need to be reset, what? and how?
If you go to VOSA website and click onto recalls then enter TOYOTA and model RX400h you will see what your car might be subject to recall for. If you have no paperwork relating to any mechanical work done on the car then Lexus should be able to tell you if your car has had the work done.
The following is from VOSA website
Vehicle Details Reference : R/2011/076 Manufacturer Ref : 1KBA-044 Make: TOYOTA Model : Lexus RX400h Launch Date : 05/08/2011 Numbers Involved : 4007 Build Start Date : 24/09/2004 Build End Date : 09/08/2006 Recall Details Concern : VEHICLE MAY LOOSE POWER Description : The Intelligent Power Module within the inverter system may fail. This will result in various warning lamps being illuminated. In most cases this will result in the vehicle entering the fail-safe mode, resulting in limited power. In limited instances the fuse on the power supply circuit could blow resulting in the hybrid system stopping. Remedial Action : Replacement of the Intelligent Power Module (IPM) in the inverter assembly. Vehicle Id : JTJHW31U#02000101 to JTJHW31U#02008127
JTJHW31U#00001030 to JTJHW31U#00049415
  • 2 months later...
hi , you will need to do an ISC reset ( idle speed control ) to set the required load when the engine cuts in , reset the windows and sunroof ( slide it back then hold the switch to forward until it goes forward , up , down , back and finally fully forwards til the closed position ) hope this helps.
