Lexus Diagnostics
What do you guys use for dtc's and diagnostics?
Particularly interested in live data for fuel trims, lambda activity etc.
Guessing dealers use Toyota based factory kit. Anyone know what its called? Is it available generally? (guessing not)
If so what's the alternative? Would prefer something specific to the manufacturer, rather than generic. Although cost is a consideration too.
Cheers
  • 1 month later...
I use an elm327 Bluetooth interface icm with the program Torque on my andriod phone ;) click here
You could do the same with an Iphone and a program called REV ps this one is very particular with the bleutooth OBD interface. check the website for it ;) click here
Also there is this program that allows you to program keys and access everything connected to the multiplex ecu ;) it's called toyota K+Can 2.0 commander but this will only run on a windows xp/vista/windows 7 laptop follow the link ;) click here
