On ‎25‎/‎09‎/‎2012 at 4:51 PM, Exdee said:
@ bluenose
A few facts about the 2nd gen IS headlights:
- If your car has headlight washers then you should have HIDs. This is the easiest way to tell.
- The projector on the car is bi-xenon too. This means that on high beam not only will the separate halogen bulb illuminate, the xenon projector will produce more light too.
- The car has AFS which activates at speeds excess of 10mph. The projector moves a few degrees left and right with the steering wheel when turning.
- The car has auto-leveling.
- The bulb type for the dipped beams is D4S.
- By default the headlights are aimed pretty low. There is a nut at the rear end of the car that can be used to adjust the height of both headlights simultaneously.
HI all,
I know this is an old post, but I'm relatively new here. I have a late 2010 IS220d F sport - The one without DRLs, and with the horizontal F-sport badge, prior to face lift.
Where is the nut at the rear end of the car for adjusting?
I was wondering if anyone has ever attempted to change the headlamps with AFS to the later model (2011 onwards) with DRL.
IMO DRLs look amazing.. do they fit?
Thanks in advance
