Lowering My Is
CoopDog
Right I've been told a couple of different things,
With the lowering springs are they 40mm drop on a standard IS or is it 40mm from the sport with the 15mm?
Also what's the max I can go on standard springs? 40mm?
Any pics of 40mm drop?
Just using springs until I can't get coil overs :)
I believe as you said it is a 40mm drop on the standard IS and would only be a 25mm drop on the sport. People have different opinions on how low you can go but generally the feeling is 40 mm can be done just with springs but any lower and you should really go with coilovers. Tenzo r springs do a 50mm drop but dont no what theyre like.
Yes same shocks. I think. And the general feeling i get from others is 40mm is the limit between a nice comfortable ride and an overly hard one. I have been looking at doing mine and i think 40mm is going to be my weapon of choice.
