Aftermarket Stereo On Is200 Clock Light Stays On And Wing Mirror Works
Megaspicywings
LEXUS IS200
YEAR : 2000
I recently had this problem with my aftermarket stereo " pioneer avh 4400bt" double din
After the install with a new bypass lead
My Battery will die after 2-3 days if not been turnt on there's a constant drain even when I'm car is off
It was driving my mental I couldn't think of why and it was just so innoying took me over a week to figure out and now I want to share with everyone who has this problem
Basically on the bypass lead where you plug it into the amp .. There will be 2 yellow wires
If you get them tested one yellow wire will be on a constant live and the other yellow with me a dead wire " while the keys are out of the ignition and turnt off "
Basically
Step one : cut the live yellow wire
Step two : cut the dead yellow wire
Step three : connect one yellow live to the one dead yellow wire
Step four : job done
Don't ask how this works but it works
Hope this helps everyone problem
Many thanks
Edward
