Is200 Rear Light Required-Drivers Side
1374lee
I am after a rear light for the IS 200 drivers side,mine are tinted though,I need a replacement as mine has a crack present so needs replacement.
I have posted in the general section as I have been told the tinted lights I have is from a later 2003/04 model? I'm really not sure on this,so if somebody could clarify this that would be a great help.
Thanks.Lee.
Just buy a pair mate .
Looking at it it does look tinted .later ones
Yes I don't mind getting a pair but there isn't any of the later ones on e bay that I can see,having said that I'm rubbish at searches on e bay.Any ideas ?
Thanks.Lee.
They're around £130.00 from Lexus but come in plain,metalic and dark metalic so you may be better to remove the cluster and see if the part number is stamped on the moulding, the last 2 letters give the colour code.
The cluster was used on all 2001-2006 models.
  • 5 weeks later...
Sourced a light off a Lexus breaker now.
Thanks.Lee.
Brilliant isn't he :)
Hi Chris,as said I'm not sure if it's the same guy you are thinking of,could be one of two that I know of?
Anyhow yes he is very good in all fairness.
Thanks.Lee.
