Engine Light Came On
Jimmy Ten Toes
Not sure exactly what the issue is but two things:
1) The "chug-home" is limp home mode. It basically enables you to travel home even though the ECU has detected a fault.
2) Take it down to a dealer, and they can plug in their Tester, and as the Engine Management light came on, they will pin-point the fault.
Yeah guessed it was in "safe mode"
Took it to dealers and it needs a new throttle body apparentely, under warranty so thats OK.
Cheers fella :winky:
