Alfred
Try putting a new Battery in the key fob if you have a new Battery in the fob already the security ecu could be malfunctioning and that will be a serious problem because if you have to replace the ecu you will need to have the keys and new ecu coded and that can only be done by Lexus .Weather they will attempt to work on your car is another issue as they may not be able to get the parts that are needed.
Hi ambermarine and Steve i deed change the Battery a new one and i got only one key with one button on aside of the key, 3 wicks ago my car was for repair painting the 4 doors they strip all the interior doors and they deed disconnect the Battery wire of the car was that the problem why the security light is off can any one help me,any advice
