Is 300 Amp Wiring
Has anyone got the wiring outputs for the wiring on the amp.
I can vaguely remember it being on the old site but cant find them anywhere.
Managed to get a phone loom with all the electrickery bits and just need the pins.
If mine work, I'll post the diagram on the site to finally end the debate on phone muting and having the sound coming through the car speakers :) :)
Any help appreciated, ta
Which phone loom have you managed to get ?
It's one that my local audio shop has made for me. He's knows his eggs and have wire one in on my Audi Allroad which has Sat Nav and Bose and Audi and Auto Leads says it's impossible to do :huh::huh:
Basically it's a 14 pin relay from Maplins with all the relevant wires coming off.
He also makes them to order so, if mine works ok I open it up for a group buy if any one is interested.....
I did a phone kit last Friday on an Audi with the bose/nav system in it. You don't need an interface kit for those. You can wire the phone's speaker output diectly into the mute and speaker inputs on the nav plug on the back of the radio.
Nice one Duncan... Thats the same thing I told a Porsche dealer the other day.....
The Lex is a little more then that.. But simply put... using a multi pin changeover relay.
That must connect on the stock amp does it, (speaker outputs)
