Wheel Bearings
teabag
Hi guys
I have noticed a light rumbleing sound coming from the road wheels of my IS200 auto, the noise dose increase with speed a little, and becomes much more noticeable when turning to right or going around a roundabout, not so bad when turning left.
I think it is probably a wheel bearing on left hand side, not sure if front or rear.
is this a common or known fault.
The car is under 3 years and is still under waranty and has 40 000 miles on it, but I would apeciate some advice before I take it to my dealer (lexus plymouth).
either wheel bearing or binding brake caliper.
Not all bearings are apparent just by seeing if there is play in the wheel.. not all have.
I had a bad bearing on my soarer.. no play at all and when the bearing was removed it fell apart
