Is200 Le Radio Reception
I have bought a new IS200 LE Auto and am delighted with the car. It was also pleasing to find this forum on the net. Whilst the car is excellent I have read that radio reception can sometimes need improvement with an aerial booster.
I am new to the forum and sorry if this has already been covered but any advice would be most welcome.
Thank You :unsure:
Thank You :unsure:
where about have you read this, i would not mind a look
I'd agree radio reception isn't the greatest.
Maybe it's worse on the later (slot at top) units ?
Oh btw, there's already an amp in the base of the aerial.
oh well a booster prob wudnt make any diff then.
Cheers 4 ya input, i neva knew there was ever anything other than a top slot :blink: Mr un-Educated over here :blush:
Tony
Thanks for your mention of there already being an amp in the base of the aerial. The Top Gear site did not make it clear - the me that is- if the problem needed a booster or has already been cured.
Reading it again in the light of your comments suggests that issue -if there was one has been solved.
How long have boosters been installed in the aerial base?
Captain Ted
I did notice that the reception, although good, is not great. I think the radio is trying to be to clever in its jumping about to find alternate freqs etc. Also, I don't think it does it fast enough. Radio 1 for instance can break up a little, loose the stereo, and only after a while does the radio think, Oh I shall hop to another freq which is stronger!!
Think its probably down to the Tuner sensitivity more thn anything else. Anyone know who they use?
I agree with the sensitivity with regard to changing stations.
If I have it set to 'TP' then when I leave work out at Woking and with Heart106.2 tuned it thinks it is not a 'TA' station and promptly looks for another one.
The reception of Heart106.2 right out on its limits is no worse than my last car though.
I put it down to the sloping aerial. When I'm approaching Woking the signal is 100% but it takes a couple of miles when facing London for it to achieve 100%.
