alternator
steveMiller72
So the charge isn't getting to the Battery via the standard connection between the alternator and the Battery?  Alternator Fuse comes to mind.  There's quite a lot on the net about it.  It's not a straightforward check so do read up on it.
If it does turn out to be the alternator fuse I'd want to know what blew it in the first place.
Direct connection means no fuse watching over a potential barbecue, but if you know how to put together this direct connection you already know about the hazards.
