I don't find my navi ID
IMG_1222.thumb.JPG.0bff79a30f386753391050ec71e5b7e2.JPGI have problem to obtain my ID because the words SETUP/"ONLINE" AND "WI-FI" are missed from my options.
NX300h F SPORT 2019 - NAVI 1540- PONB00_2_NDSLIB -
To get your device id, go the following:
  • -  Push the “MENU” hard key on the remote Touch pad
  • -  Select “Setup”
  • -  Select “Online” (you may have to scroll down)
  • -  Select “Lexus Online"
  • -  Select “Map Update Information”
If you reboot your system (hold in the power button) and have another look at the software update screen, your NavDB should update to tell you what date you currently have installed.  The system has a bug where it sometimes shows a strange code like you have at the moment.
Thanks but I know this sequence. The problem is that the last down voice of my "setup/general" is "VEHICLE".
 AT the end I can see a little triangle but it don't go up.
Is impossible to illuminate it.
I have successfully upgraded today to 1540 but nothing has changed!
Very strange. On my system if I have an item on the left hand side highlighted and ‘flick’ down on the touch pad it will scroll to more options (just like scrolling on a touch screen phone).
I’ll check tomorrow but your graphics look slightly different to mine (have you got it in split screen mode?)
The double arrow button below the touch pad is for a small number of pop up menu options in the navigation system.
This image from my manual shows the options at the left when I’m in the settings screen.  Notice the words are showing while your photo only shows the icons.
Thanks!
At the end, after hours, I have found the solution:
Swipe the finger from the middle of submenu in down direction.
Now I has the device ID and Request code.
Tomorrow I'll upgrade the maps.
Thanks for all helps.👏
