Water pump or crankshaft pulley?
Marleez
Hi Marlon. Has that noise started recently? If you wasn't going to a garage to get it looked at I'd suggest squirting some WD40 as close to the centre of any pulleys you can get to. If you do end up getting a new water pump fitted i suggest adding a few ml of ZX1 in the coolent. Also either 5 or 10 ml in with the petrol. Also put a full bottle of it in the engine oil. I totally recommend this stuff. I've been using it in all my cars fir the past 30 years. It coats any metal it comes in contact with with a molecular coating which reduces metal on metal drag etc. Let us know how you get on.
