rx450h 2014 tailgate issue
SAM CHOUHAN
can someone tell me what the problem may be with tail gate no response.
all boot lights not coming on, no blipping noise, checked the switch in glove box , can only open tail gate manually, from inside.
Any help out there?
It appears to be a common failure of the tailgate motor assembly which contains the control unit. Multiple threads on the subject have started up over recent months.
Here is one:
The only cure so far is to replace the motor assembly - which is expensive.
Hoping that some of the failed units can be investigated to see if there is a simple fix.
