RX400h four wheel alignment
 I would be pleased to hear of any members experiences of four wheel alignment on the RX, in particular problems with the rear tracking adjustment.  From what I can gather the eccentric adjustment bolts on the inner end of the track control arms can have a tendency to rust solidly in the steel centre tube of the rubber bush in the arm.  Rotating the adjustment bolt then causes the rubber to twist and possibly shear. Removal of the seized bolt may result in destruction of both bolt and arm bush.
