Hi
For ages my boot has not been closing properly, causing the trunk open light to be on when car is switched off.  So have to check that and keep shutting boot till it catches enough to shut light off, otherwise flat Battery.  On driving off, boot will quickly unlatch itself again.  Alternatively, on the about once a year it closes properly it is then very difficult to open.
Should any garage be able to mend this situation?  i.e. is it something straightforward?
(IS 250 SE [2005])
Thanks.
