P0420 error code on GS 300 MK3 2005
Hello mates,
First of all i agree there are so many post regarding P0420 and i have tried most of the suggested tricks. I am at the end stage to change my Cat. Before doing that decided to check here for the last opinion. So i only get P0420 code on low boost (city driving). If i reset the code and drive motorways no code.
I have changed spark plugs, welded the pipe(funny they found leak on bank 2 after o2 sensor), Cataclean, o2 sensor has been replaced by old owner few months back.
Any other suggestion ?
In my experience I've found the following things produce a P0420/P0430 error:
Hole in the exhaust
Upstream O2 sensors (not the downstream sensor that is reporting the issue) or potentially an air leak in the intake system/MAF sensor
Cat converter.
The error doesn't always come up because the ECU only checks for cat efficiency during certain driving situations, and if you have a cat that has lost some efficiency then it can be borderline if it passes the test or not.
P0138 normally means an electrical short, either in the wiring or the sensor itself. It's a hard fault which is almost instantly detected, which is why it comes back straightaway. That and the other codes point towards a damaged downstream sensor.
