Manual Transmission Fluid GL-5?
note
Hello,
Yet another manual transmission question:
As you know, our six speed transmission is the Aisin J160/AZ6. According to the owner's manual the fluid is 75W-90 GL-4 or GL-5.
Hoping to solve the problem with my first and second gears, which were very stiff on winter mornings, I replaced the fluid with a top-shelf product - Yacco BVX 1000 with GL-4 and GL-5 specifications.
However, the hard cold shifting remained. I later found out in some discussions that GL-5 is not recommended for this transmission as it contains some extreme pressure additives that can potentially eat away at the brass synchros. I asked Yacco and the answer was that they use "soft" technology that is safe for synchronized transmissions.
Do you think I should change the fluid again?
There are good reviews for Amsoil MTTG 75W-90, which is GL-4 and the technical bulletin shows "1B" for the copper corrosion test ASTM D130. Is this the best option I can find in Europe?
Thank you!
  • 6 months later...
So, after some research I switched to Motorcraft XT-M5-QS. The spec is GL-4.
It has very good reviews on several forums specifically for our gearbox. I also changed the transmission mount.
The shifting is now a bit smoother, especially from 1st to 2nd. Not a huge difference, but I can feel an improvement.
