Windscreen cover recommendations
With all this ice and frost around at the moment can any of you recommend a windscreen cover that works with the frameless doors we have on the RC. I have a cover from my previous car but that has flaps that are supposed to be trapped by the door, at the moment with very little wind it is working but any wind and the cover will flap away from the screen.
I would agree that conventional padded or semi-padded covers may not be suited to the RC, largely because of the geometry of the doors and windows.  I finally settled for the simple repurposing of an unlined lightweight pvc sunscreen of the type designed for external use with magnets inside the horizontal seams.  The corners easily fold into position between the window-edges and door-linings so that the fabric is pulled flat and taut against the windscreen when the doors lock and the windows fully close.  I find the screen satisfactorily protects against normal levels of frost and ice and a light layer of snow, the effects of which can be cleared with a simple good shake.  And unlike its rigid and more cumbersome equivalents, it conveniently folds away into its own small pouch for easy storage inside the cabin.  Mine is unbranded, so I can’t recommend a name, but I’m sure you’ll easily find one online or in specialist shops.
